Re: Mounting Snow Plow
Posted by john d on December 11, 2006 at 20:15:21 from (69.130.185.143):
In Reply to: Mounting Snow Plow posted by Lerm on December 11, 2006 at 13:40:47:
If you get a very robust loader for it, you can remove the bucket and attach a blade to the loader arms.
I built a 42" high x 8' wide blade that fastens to the front of my loader, which is a mid-70s Bush-Hog/Freeman 2000 model. I mount it on either my '49 M, or '52 SM.
I removed the bucket, set the loader arms inside the open side of an 8" piece of channel iron, welded some brackets to line up with the eyes on the end of the loader frame, then attached the metal for the blade. Then I used 3" channel iron to make a brace system back to the loader arms. These braces clamp to the loader arms with some long bolts. The last step was to put a short piece of 3/8" chain around the crossmember of the loader and use a big eyebolt from the chain to the top of the blade so it can't pitch forward if the bottom hits something. It doesn't angle to the side, but it will sure push through a lot of snow. It takes me 15 minutes to drop the loader bucket and attach the blade. 10 minutes to reverse the process.
Don't try this with a light-duty loader!
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
