Re: LEAKING CUB CARB
Posted by Bigdog on December 12, 2006 at 04:57:26 from (71.64.19.139):
In Reply to: LEAKING CUB CARB posted by RICK FROM VERMONT on December 11, 2006 at 16:59:02:
You have 2 problems. If you close the valve at the sediment bowl gas should not leak from the tank. Replace or repair the sediment bowl.
Secondly, the float valve can leak around the seat even if the needle / seat fit is good. Remove the seat from the carb and re-install it with some sealant to prevent leakage around the seat. This is probably a more common problem than leaking seats themselves.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D ... [Read Article]
