Re: Sticky H gears Part1
Posted by BillyinStoughton on December 12, 2006 at 09:38:10 from (69.214.162.13):
In Reply to: Re: Sticky H gears Part1 posted by Wardner on December 11, 2006 at 22:03:10:
I think you will see Wardner might be on to something. While the kerosene int the rear end is definitely effective, it has a tendency to not only lack the lubricity of a gear oil, but it also has the knack for cleaning out around all the seals enough to create more potential leaks.
When I changed the rear end oil in my H, I turned the heat up in the shop to 70 degrees and let the tractor sit overnight like that, and then pointed a small electric heater right at the rear end for a couple of hours...pulled the plug and boy I got oil, sediment, and clumps of Lord knows what! It seemed to work well though.
Just my opinion boys.
Good luck with it!
Billy
