Re: Farmall 100 transmission leaks????????????????
Posted by p8ntball329 on December 12, 2006 at 10:28:57 from (71.124.15.71):
In Reply to: Farmall 100 transmission leaks???????????????????? posted by Patrick Martin on December 12, 2006 at 10:08:30:
The first mistake you made was cleaning it out with diesel fuel. That makes those seals that are 50 years old fall apart rather fast. Those seals will probably need to be replaced.
Hope this helps
Tony
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
