Re: funk engine conversion
Posted by gene bender on December 13, 2006 at 03:14:00 from (67.55.226.214):
In Reply to: funk engine conversion posted by wegman in Mn on December 12, 2006 at 20:09:03:
The FUNCK conversion was for installing in a FORD so the stuff for would not work on a 300. Just take some measurements on the 300 to see if the frame is long enough from the bell housing to the radiator. Not that hard to do to make longer frame rails to add the 6cycl. A 300cu.in. FORD 6 would be great as it had good ratings at not a lot of rpms as you dont want engine speed over 2000 rpms. With the day of electric fans for radiators the project would be fun and neat when done.
