Re: Stuck Farmall M
Posted by 26Red on December 13, 2006 at 15:24:57 from (170.92.100.2):
In Reply to: Stuck Farmall M posted by linemanfarmer on December 13, 2006 at 15:13:13:
Depending on how long it has been stuck- I would pull the cylinder head and see what is going on in there. Could be rust, could be a stuck lifter, could have bent rod. At least drop the oil pan, pull the valve cover and remove the rocker assembly to get a better look.
Some guys have had luck pumping the stuck cylinder full of grease through the spark plug hole- you"ll have to make a fitting to get it to work.. and then pull the head to remove all the grease!
