I am not sure exactly what is wired to what, but the Wire from the F terminal on the gen should go to the field (grounded portion of the switch) The light wire goes to the light portion. On L (full CCW) the resistor for the field grouind is in the circuit to switch ground through the switch body mount. on H the resistor is not in the ground, and the charge rate is maximum, field wire direct ground through the switch body. The Field remains fully grounded in the D and B positions. There is no connection within the switch between the two systems. This diagram set should help. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
