Re: 3 Cylinders...1 to go!
Posted by Keith-OR on December 14, 2006 at 21:40:01 from (207.200.116.5):
In Reply to: Re: 3 Cylinders...1 to go! posted by JayWalt on December 14, 2006 at 20:27:19:
Jay, you can use same principle to remove blind bearings, also pilot bearing from end of a crankshaft.
1, find a shaft that fits in the opening of bearing.
2. fill cavity with grease, flush with outside of bearing.
3. place the shaft in the center opening of bearing, hit the other end of shaft with hammer. This creates hydraulic action forcing bearing to move outward.
This works really well when you can't find or do not have the right bearing puller...HTH
Keith & Shawn
