Re: O/T S-10 Ignition Key
Posted by Rob Baird on December 15, 2006 at 18:58:38 from (68.59.175.236):
In Reply to: O/T S-10 Ignition Key posted by Tom Windsor on December 15, 2006 at 18:18:43:
HI
If it is typical and I think it is. You have to remove the steering wheel. Then remove the turn signal switch you do not have to unhook the wires just pull it up and aside. Some of the lock cylinders have a screw that holds them in
the others you have to find the release button
usually there is a little slot or hole you can see
then it just pulls out
stick new one in and put everything back
I just did a Dodge truck a month or so ago
