Re: No low end torque
Posted by Janicholson on December 16, 2006 at 07:27:59 from (66.173.50.135):
In Reply to: No low end torque posted by North Dakota H puller on December 16, 2006 at 07:18:01:
Compression can always help a puller unless fuel restrictions limit the use of high octane. Using an old gasket, clay on the piston top to assess clearance, a good feel for rotating effort, and use of a die grinder/Dremel, can make it work well. Engine building is an artform. If you have flat pistons now, many choices can be found with little or no grief. A tall agressive cam may have much less torque at low speeds than you would imagine. Probably less than stock. Thus keeping RPM up will be useful. JimN
