Re: Electrical Help
Posted by El Toro on December 17, 2006 at 05:05:53 from (64.12.116.65):
In Reply to: Electrical Help posted by New Old Junk H on December 16, 2006 at 20:52:57:
Make sure you have voltage at the coil. With the points open you should have voltage on both small terminals when the ignition switch is in the on position. Use a volt meter or test lite.
Clean those points with some 320 wet or dry and then use a cotton swab dipped in alcohol and clean them several times. Make sure the point gap is at .020". Then see if tractor will start.
