Re: Update on stuck M
Posted by El Toro on December 17, 2006 at 10:08:05 from (205.188.116.133):
In Reply to: Update on stuck M posted by LinemanFarmer on December 17, 2006 at 07:59:36:
I would install a new sleeve kit as the others have suggested. Get the head reworked at your local auto machine shop and have the crankshaft measured. The cam bearings should be replaced too. The machine shop can deternine if the shaft needs to ground undersize or just needs to be polished. If it is worn slightly you can installed .002" undersize bearings. Did that on a Farmall A and the shaft looked brown before they polished it. Hal
