Re: h wide front vs tricycle
Posted by Janicholson on December 17, 2006 at 17:52:08 from (66.173.50.96):
In Reply to: h wide front vs tricycle posted by sgtbull on December 17, 2006 at 17:36:37:
In my opinion there are only two and they are small.
One is that because the operator can see the tires it is somewhat easier to track where the tractor is going. Furrows with a plow, cultivating, and other situations.
The other is that because the operator can see the tires easily there is less chance of running on into mud that gets the unit stuck. (I do not belive they have much higher flotation except that they are in a different location and may not both get into the mud at the same time.
They limit radical pivot turns
They have more wear points
They are harder to jack up (a bit)
They are less handy for parking in a "condensed" shed or garage
They require more "geometric" loader construction to clear the axle
They can't be driven with one front flat
They afford no more stability on hills (unless restrictors or modifications are made to limit or control center point pivot travel or using a centering spring to control roll, ""my opinion"")
JimN
