Re: IH Utility Steering Box
Posted by JayWalt on December 17, 2006 at 18:56:10 from (24.223.138.48):
In Reply to: IH Utility Steering Box posted by beginner on December 17, 2006 at 18:25:14:
This has been discussed alot. Since you are changing all the seals, you would probably be good with oil. People with bad seals often use grease or 90-135wt gear oil. I myself would use 135 gear oil so that the grease doesnt get a cavity in it and not lube the gears properly.
