Re: Zenith carburetor
Posted by glennster on December 18, 2006 at 05:55:34 from (68.78.73.38):
In Reply to: Zenith carburetor posted by Avery on December 18, 2006 at 05:44:10:
i would be a little nervous blowing compressed air into the fuel line of a carb. you may damage the float or drive dirt into passageways and then iit wont be easy to clean. sounds like you got fine sediment in the fuel tank, maybe rust. could also be your fuel storage tank is dirty so your getting less than clean fuel from your supplier. if the tractor tank is rusty, you could pull the tank and have it lined. a quick fix would be to your local napa auto parts, take your old fuel line with you. get 2 brass barb fittings , one for the sediment bowl and one for the carb. get either a 3031 or 3032 filter. they are small metal cannister filters, full flow for a gravity system. 3031 is for 1/4 inch lines, 3032 is for 5/16 fuel lines. they come with 2 hoses and 4 clamps. make up a rubber line with the filter in it. you can cut the origional line and splice it in, but if you are concerned with origionality, hang the old line on the workbench, and go with the rubber line.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
