Re: IH Utility Steering Box
Posted by City-Boy McCoy on December 18, 2006 at 06:20:58 from (65.0.151.8):
In Reply to: IH Utility Steering Box posted by beginner on December 17, 2006 at 18:25:14:
If you do elect to use grease, it is important to use cornhead grease. It is a very "wet" grease, holds viscosity well at broad temperature ranges and will not form an air pocket around the gears in your steering box. It gives the impression it is almost 2/3 grease - 1/3 140 wt. gear oil. It does not leak easily. It is cheap and most tractor dealerships carry it.
