Re: H no fire?
Posted by glennster on December 18, 2006 at 07:26:43 from (68.78.73.38):
In Reply to: Re: H no fire? posted by BAXTER on December 17, 2006 at 17:28:25:
your case i-h dealer will have a replacement regulator that will change over from the cut-out reg to the later style. it comes with all the instructions, pretty easy swap. take the genny in and have it tested to be sure its ok before you put the new reg on, best to take them both in at the same time. re the ignition, the wiring is pretty easy. you will find from the postive cable on the battery, it goes to the starting switch. there should be a wire coming off the post on the starter switch goes to the ignition switch, then goes to the coil. check for power at each connection. from the coil, the other wire runs to the distributor, hooks up to the points and condenser. if you got power to the coil, go into the distributor with the ignotion on, open and close the points with a screwdriver, put the coil wire near the engine to see if you got a spark jumping. you should see some sparks at the breaker points when they open and close, and get a good spark about 1/4 inch coming out of the coil wire. if not, could be bad coil, or bad points and condenser
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
