Re: Zenith carburetor
Posted by old on December 18, 2006 at 08:39:18 from (4.245.0.235):
In Reply to: Zenith carburetor posted by Avery on December 18, 2006 at 05:44:10:
Is it one with a nonadjustable main jet?? What tractor?? If its one with the nonadjustable main jet then heres how I do it when I have the problem. I pull the drain plug and also the man jet cap. Then I spray carb cleaner into the main jet and with haveing the drain plug out the dirt is flushed out the bottom of the carb and all is well again till it clogs again. Useing compressed air in the fuel line area can cause a lot of problems packing the junk and also may hurt the float and of float needle. If its a rubber tipped needle it could even blow the tip right off
