Re: No low end torque
Posted by ChadS on December 18, 2006 at 13:16:21 from (66.228.96.153):
In Reply to: Re: No low end torque posted by North Dakota H Puller on December 18, 2006 at 10:59:42:
More compression will help draw more air into the cyl, it will increase vacuum pressure cause you are moving a bit more air,, a faster air flow to be more precise,,, See,, a certain amount of vacuum pressure will mix a certain amount of fuel,,, lower levels will have alot of air, and less fuel,,, where the higher pressure will have more ability to draw fuel and air mixed in better which gives more tunability on the dyno. As far as what to do on a buildup,,,, there are litteraly 100's of options to choose from. Ill tell you about some of the engines we have done for ourselves,,, we built a 350 rowcrop this summer,,,, 175 ci, (3-5/8 bore) we took it a step further,,, we used H rods, made a bushing, and then offset drilled the wrist pin bushing higher on the rod,,, that pops the piston up more out of the bore,,, and then we remachine the piston so it fits in the head. That engine is 55hp, has a torque curve of 65 when lugged down,,,, Lots of low end torque added,,, If that was in a H frame,,, you would have a H that can run 4000,4500,5000,5500 low gear classes and have power to pull it. Then theres the stroker options,,,, Chad
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
