Re: H gas problem...
Posted by Tom Windsor on December 19, 2006 at 16:27:13 from (152.163.100.65):
In Reply to: H gas problem... posted by Chad Koel on December 19, 2006 at 14:30:36:
1. There is a screen at the end of the fuel line where it screws into the Carb. Disconnect the fuel line and then screw out the fitting with the screen on it...clean the screen. Screen may have deteriorated and allowed crud into carb passage. 2. With the fuel line disconnected, put a jar under it and open the cut off valve at the sedament bowl. See if you have a strong fuel flow. If not, then crud in the tank. Soulution: get a new sedament bowl with the standpipe and screen on it from Tractor supply. It will filter the crud and be above the crud in the bottom of your tank. If you have a strong flow, then reinstall the fuel line to the carb, open the valve and let fuel come to crab. Open the drain plug on botton of carb, if no flow or weak flow, then needle valve body at float has crud in it...Remove bottom half of carb, remove float and needle valve, remove fuel supply line and blow backwards through with air line. There are different opinions on the subject, but if it were me, I would also install a clear plastic inline filter so I could see what was happening and clean my fuel at the same time. T
Home
| Forums
Today's Featured Article -
Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
