Re: Cracked Super A Block
Posted by T_Bone on December 19, 2006 at 17:34:33 from (4.240.132.207):
In Reply to: Cracked Super A Block posted by Hartford Manning on December 18, 2006 at 17:24:05:
Hi HartFord, This would be a very easy weld repair for an experienced weldor. I would gas weld the repair using a castiron filler rod. I would start on the left crack face and V notch the crack from the bore towards the side of the block about 3/4 of a inch, weld that and let cool to room temperature covered in sand, then V-notch the horizontal crack from the bore towards the water jacket hole of 1/2 the distance, weld and cool, then v-notch the right most water jacket hole towards the 2nd bore of 1/2 the distance then weld and cool, then start back where the 1st weld was replaced and repeat the procedure as above. What this does is keep the pieces aligned in place while there welded then after there cooled then they can be finished welded without worry that the piece would shift out of position while being repaired, hence all the short welds helps. I would also make the short weld repairs as the block sits now less sleaves, pistons and such. You would then to make a small block plane with a rotor file, just like a block plane used for wood, so you can finish the weld to the block surface without damaging the block surface. I can see 4hrs really easy. So if you have to pay a weldor for a couple hours welding and then you need another couple hours in finish work, you would have about $200 into your current block, on the low end. What's it going to cost for a used block? I bet this will be the cheaper cost. T_Bone
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
