Re: Slow cranking?
Posted by John T on December 20, 2006 at 11:17:53 from (66.244.90.5):
In Reply to: Slow cranking? posted by Granger on December 20, 2006 at 08:21:23:
Garnger, I agree with Gordo and Ol Rusty, the use of 00 Gauge (especially if 6 volt) cables and to sort of milk the pistons over a lil at a time versus simply holding the button down may do the trick. Couple that with a heavy duty high CCA or Amp/Hr battery is even better. Another thing you may wanna do right off the bat is to remove, clean n wire brush shiney, and reattach each n every battery n starter n switch n ground connection n see what happens. After all that if shes still a slow cranker its time to check out the starter and switch.
John t
