Re: Plow for Super M
Posted by Carp on December 21, 2006 at 09:55:20 from (208.221.24.49):
In Reply to: Re: Plow for Super M posted by jeffalex2 on December 21, 2006 at 04:33:41:
You are making a mistake if you go with 4-14's. I pull 3-14 behind my 400 which has loaded tires and a set of weights. In sod 2nd gear is all I can pull. 3rd gear in corn stubble. If you do get the 4 bottom, you will end up only plowing 4-6' deep which is probably not what you want to do if the ground has not been plowed for 30 years.
