Re: Plow for Super M
Posted by Boyd on December 21, 2006 at 15:21:45 from (65.37.47.79):
In Reply to: Plow for Super M posted by jeffalex2 on December 21, 2006 at 02:50:02:
Keep away from the 4 bottom plow. You will be unhappy with the plow and tractor. Look around and see what other farmers are using. I have medium heavy ground here and pull a No.60 plow, 3 bottom in 2nd gear and that is plenty for it. Try for a 2 bottom 16" plow and you wll be more than happy. Happy plowing,,,,,,,,,,,,,,,,,,,Boyd
