Re: IH 460 engine?
Posted by migraine on December 21, 2006 at 20:42:53 from (71.231.54.158):
In Reply to: IH 460 engine? posted by chrisalma on December 21, 2006 at 16:28:44:
I'm sure it could be done but the narrower frame rails on the 460 would have to be altered and I think the motor will be too long to have any clearance at the radiator. 301 is usually the biggest I've heard of that goes easy into the 460. Would wonder about the trans. and rear end with that much power coming into it. Might be OK. Migraine
