Re: Leaking hydraulic pressure on 1466.
Posted by Nat 2 on December 22, 2006 at 07:31:59 from (69.204.107.149):
In Reply to: Leaking hydraulic pressure on 1466. posted by Moline_guy on December 22, 2006 at 05:30:49:
You are aware that the 3pt hitch does not provide down pressure on IH tractors, correct?
By the wording of your post, though, I would presume you mean the hydraulic remotes. These are located under the seat, and aren't too bad to work on once you get them out. The seals/orings are probably worn and need replacing.
