Re: Need trailer hitch advice schooling
Posted by HENRY E NC on December 22, 2006 at 10:01:03 from (65.210.101.97):
In Reply to: Re: Need trailer hitch advice schooling posted by MikeinKy on December 22, 2006 at 06:50:33:
For three years I pulled an 8800 lb travel trailer with a load leveler hitch ( some 35000 miles) behind a ford with a 351 ci and had no problems ecpt trransmission in truck giving out at 87000 miles. Any how. I now pull a 51 M on a trailer with 2 3500 Lb axles, 2 inch ball rated for 6000lbs traiooler weight 1400lbs . behind same truck. I also changed the rear end to a 4.11 and added helper spings total of 160$.. Works great. You can overdo everything
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
