Re: Farmall H for loader work
Posted by john d on December 22, 2006 at 22:50:31 from (69.130.191.77):
In Reply to: Farmall H for loader work posted by Sunny 4 acres on December 22, 2006 at 16:52:07:
Be patient. It's not designed to be an earth-mover, though it will do a surprising amount of work once you get used to it.
Keep the loader low, and go slow. If you're loading heavy stuff with it, spread those rear wheels, and put some weight on the back end.
