Re: Time for a Clutch?!?!
Posted by Farmall Freak on December 23, 2006 at 09:45:49 from (152.163.100.65):
In Reply to: Time for a Clutch?!?! posted by Andrew Z on December 22, 2006 at 14:21:26:
Well, you might as well pull it apart because a worn out clutch is most likely the problem. You better machine the flywheel or else the disk won't sit fully on the flywheel and that means more problems later.
