Re: Got a '41 H today- hydraulic question
Posted by kfox on December 24, 2006 at 06:00:25 from (63.18.238.123):
In Reply to: Re: Got a '41 H today- hydraulic question posted by John M on December 24, 2006 at 04:50:16:
If your not going to use the hyd. pump, you could remove the drive coupling. Might give you a couple more horsepower. Just remove the sheet metal cover on the bottom and you can get to it. Short shaft with a sleeve on each end with cotter pins through it. It probably has oil leaking out of the transmission anyway, and you can replace the seal. ken
