Re: Tool for reaming bushings
Posted by old on December 24, 2006 at 07:37:58 from (4.244.6.83):
In Reply to: Tool for reaming bushings posted by kevinez on December 24, 2006 at 07:15:12:
A hone maigh work if it doesn't need much or even a bolt with the head cut off and then a slit cut down the cneter of the bolt and emery cloth wrapped around the bolt. Chuck it up in a drill and spin it good. But thats only if you need a very small amount removed. A brake cylinder hone would probably be about the right size
