Re: Tool for reaming bushings
Posted by Roger46 on December 24, 2006 at 09:42:14 from (69.58.143.83):
In Reply to: Tool for reaming bushings posted by kevinez on December 24, 2006 at 07:15:12:
I just had the same problem with a Cub. I used a brake wheel cylinder hone. The problem is that it takes some patience, but you don't need to remove much. Roger
