Re: TA------most are out or slipping?????
Posted by Hayfarmer on December 25, 2006 at 11:29:29 from (12.160.161.153):
In Reply to: TA------most are out or slipping????? posted by GHH on December 25, 2006 at 09:05:30:
I read from lots of posts here that T/A s last a long time if used right. There must be a lot tht aren't as you see quite a few posts where TA is bad, mostly on low side. I think part of it is keeping it adjsted. It is a serious enough problem that most tractor adds you see for the earlier ta equiped tractors say " TA good" or "TA bad". When I first bought my SMTA the TA was out on the low side. I used it that way for about a year before I had to go into the PTO seasonal disconnect so had it split once. I debated on fixing it then and decided I would. I am glad I did as It is a really useful option especially on tillage or on PTO equipment. Mine was not that expensive to fix, bought a rebuild ramp and roller setup, carrier it ran on was ok and ta clutch was good, a few seals and gaskets and it was done, I did the work on it though. You can also get a TA eliminator setup but it cost about as much as repairing the TA.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
