Re: Cannot get farmall to fire
Posted by Tom Windsor on December 25, 2006 at 13:57:42 from (205.188.116.133):
In Reply to: Cannot get farmall to fire posted by Robert Corkins on December 25, 2006 at 13:51:32:
It quit "as if you turned off the ignition" This is probably exactly what happened. Take your tester and see if you have any voltage to the coil. If not, work backwards and find the break in the wire. If you have voltage, test the coil for output. The remedy is to repair and replace as needed. On this site somewhere, there is a comprehensive set of instructions for trouble shooting...I saw it recently.
TW
