Re: Cannot get farmall to fire
Posted by El Toro on December 25, 2006 at 14:21:59 from (205.188.116.133):
In Reply to: Cannot get farmall to fire posted by Robert Corkins on December 25, 2006 at 13:51:32:
Remove the distributor cap and bump the engine over to make sure the rotor is turning. If you have voltage at the coil on both small terminals
with points open, I would run apiece of 320 wet or dry through those points to clean them. Check the gap too, should be at .020".
If it still doesn't start replace the condenser.
Hal
