Re: 51 C Farmall
Posted by Janicholson on December 25, 2006 at 14:56:40 from (66.173.50.109):
In Reply to: 51 C Farmall posted by Thumbanger on December 25, 2006 at 14:48:02:
Sounds like a throw out bearing. Is it safe to say the noise is not happening when the clutch is all the way released (foot off the pedal)? If so I believe it may be the TO bearing, or fingers on the Pressure plate. Tell us more, what is the free play like, should be about an inch. JimN
