Re: Farmall Electrical System
Posted by old on December 25, 2006 at 14:58:17 from (4.245.3.103):
In Reply to: Farmall Electrical System posted by David Goode on December 25, 2006 at 13:56:06:
Sounds like you either need to put a 194 light bulb or a diode in the wire going from the excite side/terminal of the alterntor to the switch. What happens is the alternator back feeds the coil and yep no engine shut off because of it. If your useing an dleco alternator you put that lite or diode in the wire going to the #1 terminal on the little plug on it
