Re: Farmall Electrical System
Posted by John T on December 25, 2006 at 16:48:11 from (66.244.90.5):
In Reply to: Farmall Electrical System posted by David Goode on December 25, 2006 at 13:56:06:
I will cast my vote same as the gents below, since it happened after a rewiring sounds like the ignition switch is bad or more likely wired wrong,,,,,,,, or in the event it has a GM 10 SI 3 Wire alternator, perhaps you miswired a diode or an in line series resistor in its excitation circuit, cuz without one or the other and if its wired like many 3 wire alternators the coil is being backfed voltage from the alternators lil side 1R terminal excitation circuit, so she runs even with the ignition switched off. If so add a series 10 ohm current limiting safety resistor right before where it wires to the lil terminal 1R on the alternator and that should let it die when you turn off the ignition switch. If its NOT an alternator problem, get a test lamp n attach it to the IGN output terminal on the ignition switch (that wires to the coil) n see if goes on n off with the ignition switch as it should. John T
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
