1466 steering leak
Posted by brian t from ohio on December 25, 2006 at 20:50:14 from (12.75.72.85):
The steering pump under the steering wheel is leaking out the bottom. i put a new seal in it (the big cylinder shaped one on the bottom) and put it back together, torqued the bolts right according to the book and still leaks around the sleeve on the top. Leaks the same as before without replacing old seal.
