Re: H belt pulley housing
Posted by Ian T in AB on December 25, 2006 at 22:50:53 from (161.184.204.10):
In Reply to: H belt pulley housing posted by toolz on December 25, 2006 at 21:41:13:
UNBOLT THE BELT PULLY HOUSING AND LIFT IT OFF, THE 2 SHORT BOLTS, WITH NO HEAD, THAT ARE LEFT ARE GUIDE STUDS, THEY UNTHREAD WITH A SMALL PIPE WRENCH, IF NEEDED, THEN BOLT ON A COVER HOUSING FROM ANOTHER TRACTOR
