Re: 51 C Farmall
Posted by Janicholson on December 26, 2006 at 04:58:45 from (66.173.50.102):
In Reply to: 51 C Farmall posted by Thumbanger on December 25, 2006 at 14:48:02:
I have been thinking about the H noise some more and will add to the previous post that the Pilot bearng in the flywheel is also a high level suspect if the noise goes away with the trans in N and the clutch either in out, but is there with the clutch in with the trans in gear. The pilot bearing only spins when the clutch is is, and the shaft is not turning. JimN
