Re: can i sorta make a B out of a buncha junk
Posted by gene bender on December 26, 2006 at 05:56:36 from (70.240.147.189):
In Reply to: can i sorta make a B out of a buncha junk posted by tn terry t on December 26, 2006 at 03:57:40:
yes the diff shaft housing will bolt on just fine. The diff shaft will be a problem as you have to have a long shaft to replace the narrow one from the A. You can shorten a left one used on a B 4in by cutting a section from the center this has been done in the past. The housing is large enough to even use a sleeve type coupling over the shaft. Just get it true before welding. If you could be so lucky as to find one from a BN that also would work. I can make one for you if needed.
