Re: can i sorta make a B out of a buncha junk
Posted by Jim Becker on December 26, 2006 at 09:14:35 from (71.164.210.94):
In Reply to: can i sorta make a B out of a buncha junk posted by tn terry t on December 26, 2006 at 03:57:40:
You will also find:
- The brake drum will be in the wrong place on a right shaft moved to the left.
- The axle housing will not have an opening for the brake pull rod.
- You will need a BN width drawbar.
- The drop housings are left and right -- the bolt holes for the drawbar will be in the wrong place.
Bottom line: IMHO, You can sort of do it, but if you start with a buncha junk, you will end with a buncha junk.
