Re: Weight of Farmall Super MTA Cub
Posted by Nat 2 on December 26, 2006 at 12:04:42 from (64.80.108.52):
In Reply to: Weight of Farmall Super MTA Cub posted by MattofVinings on December 26, 2006 at 11:03:00:
Depends on what all is bolted to the tractor, but you should be in good shape. I mean, if these tractors have a bunch of wheel weights on them, then you might be pushing the absolute limit, but figuring typical equipment, one set of weights, you'll have 1000-1500lbs of "wiggle room" with both tractors loaded.
