Re: Farmall Electrical System
Posted by David Goode on December 26, 2006 at 14:03:17 from (69.19.14.29):
In Reply to: Farmall Electrical System posted by David Goode on December 25, 2006 at 13:56:06:
I Checked the Diode this morning along with the wiring diogarams you guys sent to me. I had wired the tractor correcty and put the diode in the correct line with the band toward the Alt. The Diode did blow do to High Voltage. It then came back to me that while rewiring the Farmall I didn't have the exact diode to replace the old one so I used the closest one I could find in my Electronics Lab. I have the diode # written down and tomarrow i should have it fixed.
-David Goode
Coggon IA
!!!!THANKS FOR ALL THE HELP!!!!
