Re: Farmall B Culti-Virsion
Posted by Janicholson on December 27, 2006 at 07:08:55 from (66.173.50.88):
In Reply to: Farmall B Culti-Virsion posted by IHC-Farmall on December 27, 2006 at 06:28:35:
If the nonstock accessories are not cobbled together, and the tractor remains operational for general use, ooorrr if the tractor is well done and special purpose and collectable for its uniqueness, it may be worth $2000, It has no hydraulic (if engine is stock) and is limited by that. JimN
