Re: Farmall B Culti-Virsion
Posted by gene bender on December 27, 2006 at 08:33:13 from (67.55.226.214):
In Reply to: Farmall B Culti-Virsion posted by IHC-Farmall on December 27, 2006 at 06:28:35:
Does your have the reduction gears. There would be a lever coming out of the bell housing on the left side below the battery box and then going near the shift lever. Some had a reduction gear mounted in the torque tube.
