Re: Future implements
Posted by CNKS on December 27, 2006 at 12:58:23 from (204.249.178.135):
In Reply to: Future implements posted by Randy as in Randy-IA on December 27, 2006 at 12:39:29:
You should have both tires the same. Usually the land tire will slip more than the furrow tire.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
