Re: C-123 engine applications and serial numbers
Posted by Stan(VA). on December 27, 2006 at 13:39:54 from (67.142.130.41):
In Reply to: Re: C-123 engine applications and serial numbers posted by David Lindsay on December 26, 2006 at 15:29:58:
Dave,
everything you described would be correct for a 200. The block would have been 354898R3, serial num is correct for the year, and description of sheetmetal is correct for 200/230 tractors. The 200 should have the rockshaft arms sticking out each side under the gas tank like the Super C, as opposed to the 230 with the hydra-touch hydraulics. You should have 200 badges on the hood. You can look over on the left and search in the tractor photos section for a farmall super c, 200, and 230 to see the sequence.
Stan(VA).
