Re: more on 404 no spark problem
Posted by Brownie450 on December 28, 2006 at 05:56:25 from (207.177.82.36):
In Reply to: more on 404 no spark problem posted by eharmon on December 27, 2006 at 20:38:33:
If you have a 12 volt test light with alligator clips, clip it on a ground & the coil terminal which comes from the ignition switch. See if the light lites up when you turn on the ignition switch. If it doesn"t, suspect a bad switch or wire between the switch & coil. Don"t remember if this unit has a resistor in the coil wire circuit or not, but if it does, check that also.
